[Qgis-developer] Oracle Plugin Error Compiling QGIS 1.8
maaza mekuria
sailmcm at yahoo.com
Tue Oct 9 16:46:53 PDT 2012
Okay I removed the Oracle raster Plugin.
I an not able to add to the menu. My C++ Plugin used to show up well at 1.7, what more has changed that it is not showing up in 1.8? I added the category property and made sure I have appropriate methods for it.
Is there a place to read what has changed? If I have missed the communication, would someone point me to where I can find the changes?
Thank you,
Maaza
--- On Tue, 10/9/12, maaza mekuria <sailmcm at yahoo.com> wrote:
> From: maaza mekuria <sailmcm at yahoo.com>
> Subject: [Qgis-developer] Oracle Plugin Error Compiling QGIS 1.8
> To: qgis-developer at lists.osgeo.org
> Date: Tuesday, October 9, 2012, 1:00 PM
> I am having difficulty compiling QGIS
> 1.8 in Windows XP using VC 2008.
> The only plugin that is ending in error (the real problem)
> is the Oracle plugin. While it compiles without error, duing
> the linking I get these two unresolved external errors about
> two methods. I can not overcome these. Would anyone shed
> some light as to what libraries I am to add. I could see
> these methods in the OGR headers in the GDAL directory. I
> even added the header file and tried compiling, but it did
> not work,
> I also was wondering why the plugins during linking do not
> generate the windows plugin dll's . I think prior to version
> 1.8 (in 1.7.x) they did generate the dll's and one did not
> need to do an install before getting the dll's.
> Thank you,
> Maaza
> 1> Creating library
> C:\GIS\myQGis\Proj\src\plugins\oracle_raster\RelWithDebInfo\oracleplugin.lib
> and object
> C:\GIS\myQGis\Proj\src\plugins\oracle_raster\RelWithDebInfo\oracleplugin.exp
> 1>qgsselectgeoraster_ui.obj : error LNK2001: unresolved
> external symbol "public: virtual char * __thiscall
> OGRGeometry::exportToGML(void)const "
> (?exportToGML at OGRGeometry@@UBEPADXZ)
> external symbol "public: virtual int __thiscall
> OGRPolygon::Centroid(class OGRPoint *)const "
> (?Centroid at OGRPolygon@@UBEHPAVOGRPoint@@@Z)
> 1>C:\GIS\myQGis\Proj\output\plugins\RelWithDebInfo\oracleplugin.dll
> : fatal error LNK1120: 2 unresolved externals
> 1>Build log was saved at
> "file://c:\GIS\myQGis\Proj\src\plugins\oracle_raster\oracleplugin.dir\RelWithDebInfo\BuildLog.htm"
> 1>oracleplugin - 3 error(s), 0 warning(s)
> ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0
> skipped ==========
> Qgis-developer mailing list
