[Qgis-developer] QGis 1.9 gdal.h not found
Justin Hubbard justin at pyrotechsoftware.com
Sun Oct 14 21:03:31 PDT 2012
Hi
I have installed the library as suggested, and have included it in the
search path. Still no Joy.
With regards to the tutorial itself, seeing as it is obsolete, is there a
more recent tutorial highlighting the basic features of the newer version
of the API?
Thanks
Justin
On Thu, Oct 11, 2012 at 5:03 PM, Etienne Tourigny
<etourigny.dev at gmail.com>wrote:
> Hi, that tutorial is quite old, and qgis has changed quite a bit since
> then...
> most probably your gdal.h is not in the include search path.
> Did you instal libgdal-dev with your package manager?
> If not you need to set CPLUS_INCLUDE_PATH and possibly C_INCLUDE_PATH to
> the include dir where you installed gdal.
> cheers
> Etienne
> On Thu, Oct 11, 2012 at 1:19 AM, Justin Hubbard <
> justin at pyrotechsoftware.com> wrote:
>> Hi
>> I am running Ubuntu 12.04, and as mentioned I was able to build Qgis
>> successfully.
>> It is when I attempt to use the Qgis libraries in a custom application
>> built in Qt Creator, that I get the error.
>> My first thought was that I need to include the gdal library in my
>> application as well, but that doesn't seem to work.
>> Any help would be appreciated
>> Thanks
>> On Wed, Oct 10, 2012 at 7:55 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>>> On 10/10/2012 06:42 AM, Justin Hubbard wrote:
>>> > Hi
>>> > I am brand new to the QGIS and Linux developer world.
>>> > I have built QGIS from source and all has gone well.
>>> > I have also been following Tim Sutton's tutorials on this development,
>>> and
>>> > while attempting to add a raster layer (tutorial
>>> > 4<http://blog.qgis.org/node/94>)
>>> > but am getting a strange error when compiling.
>>> > The qgsRasterLayer class
>>> > #include "gdal.h" which now gives me a file not found error.
>>> > I am sure that I am doing something wrong as I know that I have gdal
>>> 1.9.0
>>> > installed in the default path, and that the QGIS build found it without
>>> > problems.
>>> > Could someone please point me in the right direction.
>>> What version of linux are you on?
>>> In order to compile you need to have the -dev version of various
>>> packages (aka the source code of those packages). So you're probably
>>> missing libgdal-dev
>>> On Debian/Ubuntu the following will auto install what's needed for you:
>>> sudo apt-get build-dep qgis
>>> Though I thought the build would fail if you were missing those.
>>> Enjoy,
>>> Alex
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Warm regards
>> *Justin Hubbard*
>> *Justin Hubbard*
>> Software Engineer and Support
>>   Mobile:
>>   +27 (0)79 827 1657
>>   Fax:
>>   +27 (0)86 540 6016
>>   Email:
>>   justin at pyrotechsoftware.com <robert at plannermunicipalsoftware.co.za>
>>   Web Site:
>>   www.pyrotechsoftware.co <http://www.plannermunicipalsoftware.co.za/>m
Warm regards
*Justin Hubbard*
*Justin Hubbard*
  Mobile:
  +27 (0)79 827 1657
  Fax:
  +27 (0)86 540 6016
  Email:
  Web Site:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121015/c2b34437/attachment.html>
