[Qgis-developer] Bulding QGIS on Mac 10.8
Tasos Varoudis null at archtech.gr
Wed Oct 17 14:21:12 PDT 2012
Thanks a lot,
Ill try it. I dont think night build will do for me. I need the libs in order to link to them.
Best,
Tasos
On 17 Oct 2012, at 18:29, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi Tasos,
> On Wed, Oct 17, 2012 at 4:29 AM, Tasos Varoudis <null at archtech.gr> wrote:
>> Hello,
>> Any ideas? Im using "brew" to install deps.
>> Best
>>  Quantum-GIS git:(master) ✗ cmake -D CMAKE_VERBOSE_MAKEFILE=true -D CMAKE_BUILD_TYPE=Debug .
> Your cmake command looks a little shy on options. This is what I use:
> # force llvm instead of clang under XCode 4.4.1 (uses GNU 4.2.1)
> export CC=/usr/bin/llvm-gcc
> export CXX=/usr/bin/llvm-g++
> /usr/local/bin/cmake -D
> CMAKE_INSTALL_PREFIX="/Users/larrys/QGIS/github.com/QGIS_Apps" \
>    -D CMAKE_BUILD_TYPE="RelWithDebInfo" \
>    -D WITH_ASTYLE=FALSE \
>    -D ENABLE_TESTS=TRUE \
>    -D WITH_INTERNAL_SPATIALITE=FALSE \
>    -D WITH_PYSPATIALITE=FALSE \
>    -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
>    -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
>    -D QWT_LIBRARY=/usr/local/qwt-5.2.2/lib/libqwt.dylib \
>    -D QWT_INCLUDE_DIR=/usr/local/qwt-5.2.2/include \
>    -D BISON_EXECUTABLE=/usr/local/bin/bison \
>    -D WITH_MAPSERVER=TRUE \
>    -D WITH_APIDOC=FALSE \
>    -D QGIS_MACAPP_BUNDLE=2 \
>   ../Quantum-GIS
> Of note, the SPATIALINDEX_INCLUDE_DIR and SPATIALINDEX_LIBRARY are
> necessary for CMake to properly find the way libspatialindex is
> installed. Also, either your copy/paste failed, or you are building in
> the source directory (i.e. your command ends in just one .). Consider
> doing an out-of-source build as outlined in the INSTALL doc. My build
> directory is beside the QGIS git directory.
> These cmake options are extraneous to a basic build and can be removed:
> WITH_ASTYLE, ENABLE_TESTS, WITH_APIDOC
> You can use 'ccmake .' from your build directory to access a curses
> interface to all the pertinent cmake options, if you are not using a
> script to configure.
> My build script may be of some use to you:
> https://gist.github.com/2902743
> You will also want to manually install QScintilla2 and compile its
> Python module, which the new Python console uses (instructions are not
> currently in the INSTALL doc for Mac, but I will add it today):
> http://www.riverbankcomputing.com/software/qscintilla/download
> These are the basics (for 2.6.2):
> # install BEFORE compiling PyQt4 (or re-compile PyQt4 afterwards)
> cd <QScintilla source dir>
> cd Qt4Qt5
> qmake -spec macx-g++ qscintilla.pro
> make -j <max number of cores on Mac>
> sudo make install
> # compile/install PyQt
> cd Python
> python2.7 configure.py
> sudo make install
> # reference my build script on how to patch the module into the
> completed/installed Mac QGIS build.
> You may want to reference this previous mailing list thread:
> http://osgeo-org.1560.n6.nabble.com/Building-QGIS-in-Mac-OS-X-Mountain-Lion-i-e-10-8-with-QtSQL-support-tp4992577p4993235.html
> Lastly, if you can't get QGIS to compile, you could consider using the
> nightly build for Mac:
> http://hub.qgis.org/projects/quantum-gis/wiki/Download#421-Nightly-Builds
> Note, I do not use homebrew for anything; I just follow the INSTALL
> docs (which basically work for 10.6, 10.7, 10.8).
> Regards,
> Larry
>> -- Quantum GIS version: 1.9.0 Master (10900)
>> -- Could not find GRASS
>> -- Found Proj: /Library/Frameworks/PROJ.framework
>> -- Found GEOS: /Library/Frameworks/GEOS.framework
>> -- Found GDAL: /Library/Frameworks/GDAL.framework (1.8.1)
>> -- Found Expat: /usr/local/lib/libexpat.dylib
>> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
>> -- Found Qwt: /usr/local/lib/qwt.framework (6.0.1)
>> -- Found Sqlite3: /Library/Frameworks/SQLite3.framework
>> -- Found PostgreSQL: /usr/local/Cellar/postgresql/9.2.1/lib/libpq.dylib
>> -- Found SpatiaLite: /Library/Frameworks/SQLite3.framework
>> -- Touch support disabled
>> -- Pedantic compiler settings enabled
>> -- Debug output enabled
>> -- Found Python executable: /usr/local/bin/python
>> -- Found Python version: 2.7.3
>> -- Found Python library: -framework Python
>> -- Found SIP version: 4.13.3
>> -- Found PyQt4 version: 4.9.4
>> -- Found GSL: /Library/Frameworks/GSL.framework
>> -- txt2tags not found - disabled
>> -- Ctest Binary Directory  set to: /Users/varoudis/Desktop/Projects/Quantum-GIS/output/bin
>> -- Configuring done
>> -- Generating done
>> -- Build files have been written to: /Users/varoudis/Desktop/Projects/Quantum-GIS
>> 27%] Building CXX object src/core/CMakeFiles/qgis_core.dir/flex_qgsexpressionlexer.cpp.o
>> cd /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core && /usr/bin/c++   -Dqgis_core_EXPORTS -DQT_SVG_LIB -DQT_WEBKIT_LIB -DQT_GUI_LIB -DQT_TEST_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_NO_CAST_TO_ASCII -DQGISDEBUG=1 -D_TTY_POSIX_ -D_HAVE_PTHREAD_ -DQT_DEBUG -g -fPIC -I/usr/local/Cellar/qt/4.8.3/include -F/usr/local/Cellar/qt/4.8.3/lib -I/usr/local/Cellar/qt/4.8.3/include/QtSvg -I/usr/local/Cellar/qt/4.8.3/include/QtWebKit -I/usr/local/Cellar/qt/4.8.3/include/QtGui -I/usr/local/Cellar/qt/4.8.3/include/QtTest -I/usr/local/Cellar/qt/4.8.3/include/QtXml -I/usr/local/Cellar/qt/4.8.3/include/QtSql -I/usr/local/Cellar/qt/4.8.3/include/QtNetwork -I/usr/local/Cellar/qt/4.8.3/lib/QtCore.framework/Headers -I/Users/varoudis/Desktop/Projects/Quantum-GIS -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/composer -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/pal -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/raster -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/renderer -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/symbology -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/symbology-ng -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/gps/qextserialport -I/Library/Frameworks/GEOS.framework/Headers -I/Library/Frameworks/PROJ.framework/Headers -I/Library/Frameworks/GDAL.framework/Headers -I/Library/Frameworks/SQLite3.framework/Headers    -Wall -Wextra -Wno-long-long -Wformat-security -Wno-strict-aliasing -DCORE_EXPORT= -DGUI_EXPORT= -DPYTHON_EXPORT= -DANALYSIS_EXPORT= -DTEST_DATA_DIR="\"/Users/varoudis/Desktop/Projects/Quantum-GIS/tests/testdata\"" -F/Library/Frameworks  -w -o CMakeFiles/qgis_core.dir/flex_qgsexpressionlexer.cpp.o -c /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/flex_qgsexpressionlexer.cpp
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:29:42: error: expected class name
>> class QgisVisitor : public SpatialIndex::IVisitor
>> /usr/local/Cellar/cmake/2.8.9/bin/cmake -E cmake_progress_report /Users/varoudis/Desktop/Projects/Quantum-GIS/CMakeFiles
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:35:27: error: unknown type name 'INode'
>>    void visitNode( const INode& n )
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:38:27: error: unknown type name 'IData'
>>    void visitData( const IData& d )
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:43:39: error: unknown type name 'IData'
>>    void visitData( std::vector<const IData*>& v )
>> [ 27%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgsexpressionparser.cpp.o
>> cd /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core && /usr/bin/c++   -Dqgis_core_EXPORTS -DQT_SVG_LIB -DQT_WEBKIT_LIB -DQT_GUI_LIB -DQT_TEST_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_NO_CAST_TO_ASCII -DQGISDEBUG=1 -D_TTY_POSIX_ -D_HAVE_PTHREAD_ -DQT_DEBUG -g -fPIC -I/usr/local/Cellar/qt/4.8.3/include -F/usr/local/Cellar/qt/4.8.3/lib -I/usr/local/Cellar/qt/4.8.3/include/QtSvg -I/usr/local/Cellar/qt/4.8.3/include/QtWebKit -I/usr/local/Cellar/qt/4.8.3/include/QtGui -I/usr/local/Cellar/qt/4.8.3/include/QtTest -I/usr/local/Cellar/qt/4.8.3/include/QtXml -I/usr/local/Cellar/qt/4.8.3/include/QtSql -I/usr/local/Cellar/qt/4.8.3/include/QtNetwork -I/usr/local/Cellar/qt/4.8.3/lib/QtCore.framework/Headers -I/Users/varoudis/Desktop/Projects/Quantum-GIS -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/composer -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/pal -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/raster -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/renderer -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/symbology -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/symbology-ng -I/Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/gps/qextserialport -I/Library/Frameworks/GEOS.framework/Headers -I/Library/Frameworks/PROJ.framework/Headers -I/Library/Frameworks/GDAL.framework/Headers -I/Library/Frameworks/SQLite3.framework/Headers    -Wall -Wextra -Wno-long-long -Wformat-security -Wno-strict-aliasing -DCORE_EXPORT= -DGUI_EXPORT= -DPYTHON_EXPORT= -DANALYSIS_EXPORT= -DTEST_DATA_DIR="\"/Users/varoudis/Desktop/Projects/Quantum-GIS/tests/testdata\"" -F/Library/Frameworks  -o CMakeFiles/qgis_core.dir/qgsexpressionparser.cpp.o -c /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsexpressionparser.cpp
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:54:37: error: no member named 'createNewMemoryStorageManager' in namespace
>>      'SpatialIndex::StorageManager'
>>  mStorageManager = StorageManager::createNewMemoryStorageManager();
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:60:30: error: no member named 'createNewRandomEvictionsBuffer' in namespace
>>  mStorage = StorageManager::createNewRandomEvictionsBuffer( *mStorageManager, capacity, writeThrough );
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:67:3: error: use of undeclared identifier 'RTree'
>>  RTree::RTreeVariant variant = RTree::RV_RSTAR;
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:70:17: error: no member named 'id_type' in namespace 'SpatialIndex'
>>  SpatialIndex::id_type indexId;
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:71:12: error: use of undeclared identifier 'RTree'
>>  mRTree = RTree::createNewRTree( *mStorage, fillFactor, indexCapacity,
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:72:60: error: use of undeclared identifier 'variant'
>>                                  leafCapacity, dimension, variant, indexId );
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:77:3: warning: deleting pointer to incomplete type 'SpatialIndex::ISpatialIndex' may cause
>>      undefined behaviour [-Wdelete-incomplete]
>>  delete mRTree;
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.h:23:9: note: forward declaration of 'SpatialIndex::ISpatialIndex'
>>  class ISpatialIndex;
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.cpp:78:3: warning: deleting pointer to incomplete type 'SpatialIndex::StorageManager::IBuffer' may
>>      cause undefined behaviour [-Wdelete-incomplete]
>>  delete mStorage;
>> /Users/varoudis/Desktop/Projects/Quantum-GIS/src/core/qgsspatialindex.h:29:11: note: forward declaration of 'SpatialIndex::StorageManager::IBuffer'
>>    class IBuffer;
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
