[Qgis-developer] Building QGIS against GRASS 7
Vladimir Naumov
sendmeoffer at gmail.com
Thu Oct 18 06:49:16 PDT 2012
Hi list,
I have similar problem as Paulo:
http://lists.osgeo.org/pipermail/qgis-user/2012-April/016557.html
I am trying to compile QGIS against the latest GRASS 7. But ccmake
refuses to set variable LIB_PATH correctly, it uses its default one
(/usr/lib/grass64/lib/libgrass_gproj.so).
GDAL 1.9.2, released 2012/10/08
GRASS version: 7.0.svn
GRASS SVN Revision: 53433
GIS Library Revision: 52468 (2012-07-28)
GDAL/OGR: 1.9.2
Python: 2.7.2+
wxPython: 2.8.11.0
Platform: Linux-3.0.0-26-generic-pae-i686-with-Ubuntu-11.10-oneiric
Is it possible to build QGIS against GRASS 7? Why does ccmake set the
variable to default?
Best regards,
Vladimir.
