[Qgis-developer] R Sextante error
Victor Olaya volayaf at gmail.com
Fri Oct 19 01:01:40 PDT 2012
Agustin
The most useful info here is in the Rlog file that you will find in
[your-user-folder]/sextante
That tells us what was the problem with R (if any). Could you please send it?
thanks for your help
Victor
2012/10/19 Agustin Lobo <alobolistas at gmail.com>:
> I find  problem at trying to run R scripts within Sextante
> on ubuntu 10.04 + qgis 1.8
> I include links to screen captures of the results at attempting to run
> the provided example script "Create random sample grid":
> http://dl.dropbox.com/u/3180464/Rsextante1.jpeg
> http://dl.dropbox.com/u/3180464/Rsextante2.jpeg
> http://dl.dropbox.com/u/3180464/Rsextante3.jpeg
> http://dl.dropbox.com/u/3180464/Rsextante4.jpeg
> I've seen a couple or R-Sextante tickets in
> http://hub.qgis.org/projects/sextante/issues
> but I think that they are not related to this, as it seems that
> those users were able to go beyond than I've been. It also seems like R Sextante
> might be working on windows and not on linux?
> Should I open a ticket for this in
> http://hub.qgis.org/projects/sextante/issues ?
> Thanks
> Agus
> QGIS version 1.8.0-Lisboa
> QGIS code revision exported
> Compiled against Qt4.6.2
> Running against Qt4.6.2
> Compiled against GDAL/OGR1.9.1
> Running against GDAL/OGR1.9.1
> GEOS Version3.3.3
> PostgreSQL Client Version8.4.12
> SpatiaLite Version2.4.0
> QWT Version5.2.0
> Qgis-developer mailing list
