[Qgis-developer] R Sextante error
rldhont
rldhont at gmail.com
Fri Oct 19 06:06:51 PDT 2012
Hi Victor,
Ticket opens and patch supplies
http://hub.qgis.org/issues/6545
René-Luc
Le 19/10/2012 10:15, Victor Olaya a écrit :
> That makes sense...
> Please open a ticket and provide a patch, and I will apply it ASAP
> Many thanks!
> Victor
> 2012/10/19 rldhont <rldhont at gmail.com>:
>> Hi all,
>> With a friend of mine, we identifying a bug on Ubuntu with R in sextante.
>> The bug is : The python subprocess doesn't execute the command.
>> The solution put the parameter shell to False on linux for the subprocess
>> Popen construction.
>> Python doc http://docs.python.org/library/subprocess.html#popen-constructor
>> On Windows with shell=True, the COMSPEC environment variable specifies the
>> default shell. The only time you need to specify shell=True on Windows is
>> when the command you wish to execute is built into the shell (e.g. dir or
>> copy). You do not need shell=True to run a batch file or console-based
>> executable.
>> If you want I can open an issue and provide a patch.
>> Regards,
>> René-Luc
>> Le 19/10/2012 10:01, Victor Olaya a écrit :
>>> Agustin
>>> The most useful info here is in the Rlog file that you will find in
>>> [your-user-folder]/sextante
>>> That tells us what was the problem with R (if any). Could you please send
>>> it?
>>> thanks for your help
>>> Victor
>>> 2012/10/19 Agustin Lobo <alobolistas at gmail.com>:
>>>> I find problem at trying to run R scripts within Sextante
>>>> on ubuntu 10.04 + qgis 1.8
>>>> I include links to screen captures of the results at attempting to run
>>>> the provided example script "Create random sample grid":
>>>> http://dl.dropbox.com/u/3180464/Rsextante1.jpeg
>>>> http://dl.dropbox.com/u/3180464/Rsextante2.jpeg
>>>> http://dl.dropbox.com/u/3180464/Rsextante3.jpeg
>>>> http://dl.dropbox.com/u/3180464/Rsextante4.jpeg
>>>> I've seen a couple or R-Sextante tickets in
>>>> http://hub.qgis.org/projects/sextante/issues
>>>> but I think that they are not related to this, as it seems that
>>>> those users were able to go beyond than I've been. It also seems like R
>>>> Sextante
>>>> might be working on windows and not on linux?
>>>> Should I open a ticket for this in
>>>> http://hub.qgis.org/projects/sextante/issues ?
>>>> Thanks
>>>> Agus
>>>> QGIS version 1.8.0-Lisboa
>>>> QGIS code revision exported
>>>> Compiled against Qt4.6.2
>>>> Running against Qt4.6.2
>>>> Compiled against GDAL/OGR1.9.1
>>>> Running against GDAL/OGR1.9.1
>>>> GEOS Version3.3.3
>>>> PostgreSQL Client Version8.4.12
>>>> SpatiaLite Version2.4.0
>>>> QWT Version5.2.0
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
