[Qgis-developer] R Sextante error
Victor Olaya volayaf at gmail.com
Fri Oct 19 01:15:22 PDT 2012
That makes sense...
Please open a ticket and provide a patch, and I will apply it ASAP
Many thanks!
Victor
2012/10/19 rldhont <rldhont at gmail.com>:
> Hi all,
> With a friend of mine, we identifying a bug on Ubuntu with R in sextante.
> The bug is : The python subprocess doesn't execute the command.
> The solution put the parameter shell to False on linux for the subprocess
> Popen construction.
> Python doc http://docs.python.org/library/subprocess.html#popen-constructor
> On Windows with shell=True, the COMSPEC environment variable specifies the
> default shell. The only time you need to specify shell=True on Windows is
> when the command you wish to execute is built into the shell (e.g. dir or
> copy). You do not need shell=True to run a batch file or console-based
> executable.
> If you want I can open an issue and provide a patch.
> Regards,
> René-Luc
> Le 19/10/2012 10:01, Victor Olaya a écrit :
>> Agustin
>> The most useful info here is in the Rlog file that you will find in
>> [your-user-folder]/sextante
>> That tells us what was the problem with R (if any). Could you please send
>> it?
>> thanks for your help
>> Victor
>> 2012/10/19 Agustin Lobo <alobolistas at gmail.com>:
>>> I find  problem at trying to run R scripts within Sextante
>>> on ubuntu 10.04 + qgis 1.8
>>> I include links to screen captures of the results at attempting to run
>>> the provided example script "Create random sample grid":
>>> http://dl.dropbox.com/u/3180464/Rsextante1.jpeg
>>> http://dl.dropbox.com/u/3180464/Rsextante2.jpeg
>>> http://dl.dropbox.com/u/3180464/Rsextante3.jpeg
>>> http://dl.dropbox.com/u/3180464/Rsextante4.jpeg
>>> I've seen a couple or R-Sextante tickets in
>>> http://hub.qgis.org/projects/sextante/issues
>>> but I think that they are not related to this, as it seems that
>>> those users were able to go beyond than I've been. It also seems like R
>>> Sextante
>>> might be working on windows and not on linux?
>>> Should I open a ticket for this in
>>> http://hub.qgis.org/projects/sextante/issues ?
>>> Thanks
>>> Agus
>>> QGIS version 1.8.0-Lisboa
>>> QGIS code revision exported
>>> Compiled against Qt4.6.2
>>> Running against Qt4.6.2
>>> Compiled against GDAL/OGR1.9.1
>>> Running against GDAL/OGR1.9.1
>>> GEOS Version3.3.3
>>> PostgreSQL Client Version8.4.12
>>> SpatiaLite Version2.4.0
>>> QWT Version5.2.0
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
