[Qgis-developer] PyQGIS: QGIS segfaults when using Qgsvectorlayer.select() inside signal handler
Rafael Varela Pet
rafael.varela at gmail.com
Fri Oct 19 09:27:27 PDT 2012
Looking at the source code in the git repository I found out that most
of the Qgsvectorlayer::select() functionality resides in the data
provider, so I decided to write the layers to disk and switch the
layer data provider from "memory" to "ogr".
The problem still persists, so I decided to file a bug report (#6547).
2012/10/13, Rafael Varela Pet <rafael.varela at gmail.com>:
> Hi again,
> I forgot to mention that QGIS only segfaults when using the node tool
> of mDigitizeToolBar.
> It does not crash when I use the move feature tool.
> 2012/10/13 Rafael Varela Pet <rafael.varela at gmail.com>:
>> I'm developing a python plugin in QGIS 1.9.0-master that makes QGIS
>> segfault when I call Qgsvectorlayer.select() inside a geometryChanged
>> signal handler
>> My code looks like this:
>> layer_A.geometryChanged.connect(self.onLineGeometryChange)
>> @pyqtSlot(int, QgsGeometry)
>> def onLineGeometryChange(self, featureId, geom ):
>> layer_B.select( someRectangle, False )
>> Is it illegal to call "select()" inside "onLineGeometryChange()"?
>> By the way, I'm not really interested in selecting features. I only
>> wanted to find the existing features inside a map area, but I didn't
>> find any other way but using "select()"
Regards,
Rafael Varela
