[Qgis-developer] PyQGIS: QGIS segfaults when using Qgsvectorlayer.select() inside signal handler
Rafael Varela Pet
rafael.varela at gmail.com
Sat Oct 13 04:14:59 PDT 2012
Hi again,
I forgot to mention that QGIS only segfaults when using the node tool
of mDigitizeToolBar.
It does not crash when I use the move feature tool.
2012/10/13 Rafael Varela Pet <rafael.varela at gmail.com>:
> I'm developing a python plugin in QGIS 1.9.0-master that makes QGIS
> segfault when I call Qgsvectorlayer.select() inside a geometryChanged
> signal handler
> My code looks like this:
> layer_A.geometryChanged.connect(self.onLineGeometryChange)
> @pyqtSlot(int, QgsGeometry)
> def onLineGeometryChange(self, featureId, geom ):
> layer_B.select( someRectangle, False )
> Is it illegal to call "select()" inside "onLineGeometryChange()"?
> By the way, I'm not really interested in selecting features. I only
> wanted to find the existing features inside a map area, but I didn't
> find any other way but using "select()"
Regards,
Rafa
