[Qgis-developer] setPkgDataPath issue
Sandro Santilli
strk at keybit.net
Wed Oct 24 00:22:54 PDT 2012
Larry, I commented out the setPkgDataPath line because with
that load of GdalTools plugin out of output/python/plugin path
fails with this message:
File "/usr/src/qgis/Quantum-GIS/b/output/python/qgis/utils.py", line 188, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "/usr/src/qgis/Quantum-GIS/python/plugins/fTools/__init__.py", line 53, in classFactory
which seems to mean that the startPlugin function, loaded from output dir,
finds the __init__.py file in the _source_ dir rather than finding the one
in output dir.
The same kind of error happens with _all_ the plugins, not only GdalTools.
I understand from your commit log that something else broke without that line,
can we find another way to fix it ? Can you explain what the problem was ?
I don't know what "crssync" is...
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
