[Qgis-developer] QtSQL location has moved PySide
Alex Mandel
tech_dev at wildintellect.com
Fri Oct 26 11:16:48 PDT 2012
On 10/25/2012 11:32 PM, Martin Dobias wrote:
> On Fri, Oct 26, 2012 at 3:54 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> On some OS it looks like the location of the python bindings to qtsql
>> has moved and is causing any plugin that imports to fail.
>> Specifically on ubuntu 12.04 and newer it's inside pyside. I'm not sure
>> if this affects other systems (Win/Mac). So it might be advised for
>> plugin authors to do an if statement or a try/except to catch the right
>> load.
>> Old:
>> from PyQt4.QtSql import *
>> New:
>> from PySide.QtSql import *
> Hi Alex
> are you sure it has been moved? PyQt4 and PySide are separate
> projects, both of them should have their own QtSql module. Isn't that
> just missing python-qt4-sql package on your side? Maybe your fix
> works, but I would be afraid of some incompatibilities between PyQt4
> and PySide that are hard to predict.
> Martin
Ah I think I was having trouble finding the pyqt version of it. I think
I found it now in the package:
python-qt4-sql
Will double check that one works.
Thanks,
Alex
