[Qgis-developer] Building ".so" plugin, not ".dylib" on Mac
William Kyngesburye woklist at kyngchaos.com
Tue Oct 30 07:40:48 PDT 2012
If you are doing both of those at the same time, I'm guessing that dynamiclib (probably synonym for dylib) is overriding bundle.
You can figure out what it really linked as with:
  file /path/to/your/plugin
But then, the difference between a dylib and a bundle is not a big one - a dylib can be loaded like a bundle.  Maybe there is a different problem?
On Oct 30, 2012, at 9:22 AM, Tasos Varoudis wrote:
> Hi,
> So something like that should work:
> macx:QMAKE_LFLAGS_PLUGIN -= -dynamiclib
> macx:QMAKE_LFLAGS_PLUGIN += -bundle
> But it didn't.
> I still get a dylib file and if I rename it to .so QGIS will crash (as it really a dylid and qgis is confused) or not load at all (if I leave it as dylib and move it to the plugin folder).
> Thanks
> Tasos
> On 30 Oct 2012, at 13:46, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> You need to use a MODULE type for the cmake ADD_LIBRARY().  I don't know how to do this with qmake, but the linker flag is -bundle instead of -dylib.
>> On Oct 30, 2012, at 4:54 AM, Tasos Varoudis wrote:
>>> Hi all,
>>> Im using qmake to build a C++ plug.
>>> On mac I get a .dylib and I can't load it in the same way as in other OSs.
>>> Im not sure, but I think has something to do this the dylib, as the cmake official build is producing .so files for the plugs.
>>> Even though I search I can't make qmake produce a .so lib on mac.
>>> Any ideas? help?
>>> Best,
>>> Tasos
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
The equator is so long, it could encircle the earth completely once.
