[Qgis-developer] Qgis Server and Python. Which solutions to have a python API?
G. Allegri
giohappy at gmail.com
Mon Sep 10 04:13:28 PDT 2012
2012/9/10 kimaidou <kimaidou at gmail.com>
> Hi Giovanni,
> * The print service will be supported in the next version. Not yet to
> follow the "release often" mantra
Do you have a schedule for the next version?
> * We think rights management must be kept simple for users. This is why we
> choose deliberately to manage rights per repositories and not per project
> nor layers. We think it is very easy to set up several dedicated projects
> with Qgis to fit the need to protect some layers. One simple project a.qgs
> for readers with layer A and B and this configuration, another
> mrpresident.qgs for the big boss with all the secret layers and all the
> zoom available, etc.
We also thought it but it requires to propagate project and layers settings
to the various projects, A change in one project requires to manually do
the same on the others... Ok, not so bad for two or three projects, but
very time consuming if you have multiple roles = multiple projects.
Anyway, I agree with you, it's times simpler to implement ;)
> * Why not though add in the future the possibility to manage permissions
> on request type (getCapabilities, getMap, getFeatureInfo, etc.).
Ok.
Our goals are very similar. We will think on it...
giovanni
> Michael
> 2012/9/10 G. Allegri <giohappy at gmail.com>
> Hi Michael,
>> the two projects will probably overlay similar features. We've never
>> worked with Jelix, and we didn't want to learn another framework :)
>> Anyway, sharing ideas is always the best way for OS projects.
>> A couple of questions:
>> - will you support the print service?
>> - I haven't tried Lizmap yet. Does it handle rights permissions on
>> single layers within a .qgs project? Can you manage permissions on the
>> request types (e.g. getfeatureinfo, getcapabilities, etc.)?
>> It would be great if you could setup an SCM (bitbucket, github, or
>> whatelse).
>> giovanni
>>> Hi all,
>>> Lizmap will be release soon, as a Zip file. I do not know yet if I will
>>> create a bitbucket account to put the code here or not. Why not !
>>> Some of next lizmap features :
>>> * access rights management to repositories (1 repository = one folder in
>>> the server containing one or more projects). You can defined, groups,
>>> users, and then set the visibility of each repository to one or more groups.
>>> * simple approach of tile caching, with no configuration needed (just
>>> click on a checkbox in Lizmap plugin for each layer to be cached)
>>> * new ui, etc.
>>> I am writing some documentation right now, and will explain these
>>> features as soon as I find time :)
>>> Cheers
>>> Michael
>>> 2012/9/10 Tim Sutton <lists at linfiniti.com>
>>>> Hi
>>>> On Mon, Sep 10, 2012 at 12:01 PM, G. Allegri <giohappy at gmail.com>
>>>> wrote:
>>>> > Hi,
>>>> > the project is in very early development state. We've just
>>>> implemented some
>>>> > basic things for the current client we are working for, but we want
>>>> to go on
>>>> > with the development.
>>>> > We're aware of LizMap (we're looking forward for its new release;
>>>> question,
>>>> > is there a public repository?), but we prefer to use Django, because
>>>> it will
>>>> > let us leaverage the Qgis Python APIs in case we will need them
>>>> (probably
>>>> > yes).
>>>> > In this moment we're using qgis-web-client as it is beacuse it fits
>>>> our
>>>> > current needs (e.g. we don't need external base layers, it already
>>>> supports
>>>> > the Qgis Server print service, etc.) but I would like to implement a
>>>> > Javascript API to be used independently by any JS framework.
>>>> > Lots of ideas... we hope to find the needed sponsors to implement
>>>> them all!
>>>> > We'll release something as soon as we have a minimally stable project.
>>>> > giovanni
>>>> Cool - it might be nice to put your work in
>>>> http://github.com/qgis/XXXX if you want to do it pubicly.
>>>> Regards
>>>> Tim
>>>> > 2012/9/10 rldhont <rldhont at gmail.com>
>>>> >> Le 10/09/2012 09:29, Giovanni Manghi a écrit :
>>>> >>> Hi Giovanni,
>>>> >>>> On Sat, Sep 8, 2012 at 11:18 AM, G. Allegri <giohappy at gmail.com>
>>>> wrote:
>>>> >>>>> I'm working on a project to port qgis-web-client under Django,
>>>> witht
>>>> >>>>> the aim
>>>> >>>>> to build a Qgis Server web based manager and extended service
>>>> provider.
>>>> >>>>> We've already implemented a basic structure, with a proxy (a
>>>> Django
>>>> >>>>> view) to
>>>> >>>>> intercept the calls to qgis_mapserv.fcgi, and a view/template to
>>>> expose
>>>> >>>>> the
>>>> >>>>> qgis-web-min.
>>>> >>> very nice! will the code be released?
>>>> >> Stay tuned, a new LizMap version will be released soon (today or
>>>> tomorrow)
>>>> >> Cheers,
>>>> >> René-Luc D'Hont
>>>> >> 3Liz
>>>> >>> cheers!
>>>> >>> -- Giovanni --
>>>> >>> _______________________________________________
>>>> >>> Qgis-developer mailing list
>>>> >>> Qgis-developer at lists.osgeo.org
>>>> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>>>> Please do not email me off-list with technical
>>>> support questions. Using the lists will gain
>>>> more exposure for your issues and the knowledge
>>>> surrounding your issue will be shared with all.
>>>> Visit http://linfiniti.com to find out about:
>>>> * QGIS programming and support services
>>>> * Mapserver and PostGIS based hosting plans
>>>> * FOSS Consulting Services
>>>> Skype: timlinux
>>>> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120910/cb815acc/attachment-0001.html>
