[Qgis-developer] Qgis Server and Python. Which solutions to have a python API?
kimaidou
kimaidou at gmail.com
Mon Sep 10 05:47:17 PDT 2012
Tim,
I do not know this feature... I will search in the documentation to see how
I can use it !
This is great :)
Thanks,
Michael
2012/9/10 Tim Sutton <lists at linfiniti.com>
> Hi
> Are you aware of the project nesting capability Marco added? It should
> provide you with the 'define once, use many times' implementation you
> desire.
> Regards
> Tim
> >A change in one project requires to manually do the
> > same on the others... Ok, not so bad for two or three projects, but very
> > time consuming if you have multiple roles = multiple projects.
> > Anyway, I agree with you, it's times simpler to implement ;)
> >> * Why not though add in the future the possibility to manage permissions
> >> on request type (getCapabilities, getMap, getFeatureInfo, etc.).
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120910/b6eeafd8/attachment.html>
