[Qgis-developer] Qgis Server and Python. Which solutions to have a python API?
Tim Sutton
lists at linfiniti.com
Mon Sep 10 05:58:35 PDT 2012
Hi
On Mon, Sep 10, 2012 at 2:47 PM, kimaidou <kimaidou at gmail.com> wrote:
> Tim,
> I do not know this feature... I will search in the documentation to see how
> I can use it !
> This is great :)
Its under Layer -> Embed layers and groups
Regards
Tim
> Thanks,
> Michael
> 2012/9/10 Tim Sutton <lists at linfiniti.com>
>> Hi
>> Are you aware of the project nesting capability Marco added? It should
>> provide you with the 'define once, use many times' implementation you
>> desire.
>> Regards
>> Tim
>> >A change in one project requires to manually do the
>> > same on the others... Ok, not so bad for two or three projects, but very
>> > time consuming if you have multiple roles = multiple projects.
>> > Anyway, I agree with you, it's times simpler to implement ;)
>> >> * Why not though add in the future the possibility to manage
>> >> permissions
>> >> on request type (getCapabilities, getMap, getFeatureInfo, etc.).
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
