[Qgis-developer] Nightly builds of master branch for Mac
Larry Shaffer
larrys at dakotacarto.com
Thu Sep 13 20:12:12 PDT 2012
On Thu, Sep 13, 2012 at 5:46 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> On Sep 13, 2012, at 12:09 PM, Larry Shaffer wrote:
>>> If I want to test this version, I need to migrate or learn to compile QGIS
>>> (take some time, i am geologist and not a programmer). It's very frustrating
>>> and I do not think that I was alone .
>> Sorry about the frustration. It is really just an issue (for the most
>> part) with which system Python version is supported. William's
>> installers manage both versions of Python, relative to OS being
>> installed on [0]. My nightly builds are only compiled against the
>> system Python version 2.7, Snow Leopard only comes with up to 2.6. I
>> suppose I could just as easily make a second build that supports
>> Python 2.6. That would be considerably easier for me than trying to
>> automate creating an installer package.
>> I will look into this today and get back to you.
> Configure options I use to compile for Snow Python 2.6:
> export MACOSX_DEPLOYMENT_TARGET=10.6
> export DESTDIR=~/Applications/qgis-release
> export CFLAGS="-isysroot /Developer/SDKs/MacOSX10.6.sdk"
> export CXXFLAGS="-isysroot /Developer/SDKs/MacOSX10.6.sdk"
> export LDFLAGS="-isysroot /Developer/SDKs/MacOSX10.6.sdk"
> cmake ... \
> -D CMAKE_OSX_DEPLOYMENT_TARGET="10.6" \
> -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.6.sdk" \
> -D PYTHON_EXECUTABLE=/usr/bin/python2.6 \
> -D SIP_BINARY_PATH=/Users/Shared/unix/python-snow/bin/sip \
> Any external dependencies (like the QScintilla2 you added, and Qwt, spatialindex, ...) must be also compiled with the 10.6 deployment target. My frameworks are OK. The sip bit above assumes a separate SIP/PyQt compiled for 10.6 in the system Python 2.6 site-packages. But compiling SIP/PyQt *for* Snow Python 2.6 *on* Lion is tricky, and needs a hack to the system Python. (the simple solution is to compile on Snow)
@William, thanks for the help. I settled on the latter, '(the simple
solution is to compile on Snow)'. :^)
@Gene, please test the Snow Leopard master nightly on your 64-bit-capable Macs:
http://qgis.dakotacarto.com
You might see intermittent builds over the next few days, until I can
verify the nightly build script works on that older Core 2 Duo server
and that it reports the unit tests correctly.
Regards,
Larry
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
> - the wisdom of Tarzan
