[Qgis-developer] Blank rasters when using compression options with save as
Etienne Tourigny
etourigny.dev at gmail.com
Fri Sep 14 17:37:05 PDT 2012
Ok I was able to replicate, using the file tenbytenraster.asc as
input, but other grayscale images load fine (i.e. landsat_b1.tif).
However, if I convert it to a gtiff file externally with gdal, the
resulting gtiff file can be saved in qgis with compression options.
Can you replicate that?
Have you tried with other (real) files?
Etienne
On Fri, Sep 14, 2012 at 6:57 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Fri, Sep 14, 2012 at 10:33 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> Hi
>> working fine for me, but only tried today with the same file
>> landsat.tiff. When I implemented it I tried with large-ish files
>> without problems.
>> Maybe it's with a specific file you are having problems?
> I was able ot replicate with any of the grayscale images in the test data dir.
> Regards
> Tim
>> Etienne
>> On Fri, Sep 14, 2012 at 5:02 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>> Hi All
>>> Does anyone else get an issue where rasters are all NULL when enabling
>>> compression options in the new save as dialog? Etienne is it working
>>> ok for you?
>>> Regards
>>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Visit http://linfiniti.com to find out about:
>>> * QGIS programming and support services
>>> * Mapserver and PostGIS based hosting plans
>>> * FOSS Consulting Services
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Skype: timlinux
