[Qgis-developer] Blank rasters when using compression options with save as
Tim Sutton lists at linfiniti.com
Mon Sep 17 12:54:51 PDT 2012
Hi
On Sat, Sep 15, 2012 at 2:37 AM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Ok I was able to replicate, using the file tenbytenraster.asc as
> input, but other grayscale images load fine (i.e. landsat_b1.tif).
> However, if I convert it to a gtiff file externally with gdal, the
> resulting gtiff file can be saved in qgis with compression options.
> Can you replicate that?
> Have you tried with other (real) files?
Sorry for the delay in replying. Yes indeed. I'm sending you an example offlist.
Also the new profile combo at the bottom of the save as dialog is a
little confusing as it seems to replicate the functionality up top.
Regards
Tim
> Etienne
> On Fri, Sep 14, 2012 at 6:57 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Fri, Sep 14, 2012 at 10:33 PM, Etienne Tourigny
>>> Hi
>>> working fine for me, but only tried today with the same file
>>> landsat.tiff.  When I implemented it I tried with large-ish files
>>> without problems.
>>> Maybe it's with a specific file you are having problems?
>> I was able ot replicate with any of the grayscale images in the test data dir.
>> Regards
>> Tim
>>> Etienne
>>> On Fri, Sep 14, 2012 at 5:02 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>>> Hi All
>>>> Does anyone else get an issue where rasters are all NULL when enabling
>>>> compression options in the new save as dialog? Etienne is it working
>>>> ok for you?
>>>> Regards
>>>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>>>> Please do not email me off-list with technical
>>>> support questions. Using the lists will gain
>>>> more exposure for your issues and the knowledge
>>>> surrounding your issue will be shared with all.
>>>> Visit http://linfiniti.com to find out about:
>>>>  * QGIS programming and support services
>>>>  * Mapserver and PostGIS based hosting plans
>>>>  * FOSS Consulting Services
>>>> Skype: timlinux
>>>> Irc: timlinux on #qgis at freenode.net
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Skype: timlinux
Skype: timlinux
