[Qgis-developer] Default typeface to package with app
G. Allegri
giohappy at gmail.com
Sat Sep 15 15:05:56 PDT 2012
Sent from Nexus
Il giorno 15/set/2012 23:21, "G. Allegri" <giohappy at gmail.com> ha scritto:
> I agree with you Larry. Your reasons are similar to those undergoing the
choice of having an embedded font, and it is DejaVu ;-)
I missed a line, I meant the reason of the Mapnik project, which adopted
DejaVu too.
> giovanni
> Sent from Nexus
> Il giorno 15/set/2012 22:33, "Larry Shaffer" <larrys at dakotacarto.com> ha
scritto:
>> Hi,
>> Not sure if this has been discussed before, but how about including a
>> default typeface to package with releases/source? Here are several
>> reasons for doing so:
>> * Standard QFontMetrics allow for developing a GUI overhaul around a
>> known font across all platforms (at least in a pointsize at dpi default
>> sense).
>> * Known font metrics allow for standardizing relative font sizes in
>> app-wide stylesheets, and per platform where needed.
>> * Adding tests for the labeling engine would need a standard font of
>> consistent metrics and available/functional on all platforms.
>> * Currently the only Qt default font on all platforms (Courier, I
>> believe) is not necessarily of similar metrics, since it is from
>> various sources, nor is it IMHO very nice looking (apologies to any
>> Courier fans).
>> * Have a better/consistent monospaced font for the Python Console and
>> anywhere editor instances (e.g. QScintilla2) or code snippets are
>> displayed.
>> * Have a known set of available Unicode glyphs for translators to rely
upon.
>> * Have a default font that provides a known set of Unicode glyphs for
>> font markers in symbology. (Could be spread across multiple default
>> symbol fonts.)
>> * Provide workarounds for QtDesigner bug where platform-specific fonts
>> end up embedded in .ui files [0].
>> There are probably other good reasons. I've looked at several typeface
>> candidates and think the DejaVu project's family of fonts [1] would
>> work well. While DejaVu (based off of Bitstream's Vera Sans) is
>> already available for Ubuntu and other Linux distros, it is relatively
>> unused, though fully compatible, on all supported QGIS platforms [2].
>> Downside: about 5 MBs extra (compressed) for package.
>> As a TTF DejaVu can readily be loaded into QFontDatabase [3] on
>> platforms that do not have a compatible DejaVu typeface already
>> installed. This would probably entail only loading 4 heavily-used
>> faces, like Sans Book/Bold and Mono Book/Bold, though I think the
>> entire typeface should be included.
>> Any other ideas for embedded fonts? Note: fonts to consider should be
>> in TTF format, offer enough font faces, provide enough language and
>> Unicode character support, and be available under the SIL Open Font
>> [4] or similarly compatible license.
>> [0] Search for 'font-family:' in .ui files
>> [1] http://dejavu-fonts.org/wiki/Main_Page
>> [2] http://en.wikipedia.org/wiki/DejaVu_fonts
>> [3]
http://qt-project.org/doc/qt-4.7/qfontdatabase.html#id-5441ac2b-3b52-411e-b2be-7ee83eef8041
>> [4] http://en.wikipedia.org/wiki/SIL_Open_Font_License
>> Regards,
>> Larry
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120916/6887dfcb/attachment-0001.html>
