[Qgis-developer] Colors selection when adding multiple layers could be improved
Gabriele Monfardini gabrimonfa at gmail.com
Fri Sep 21 06:28:31 PDT 2012
When adding multiple layers to a map for quick data inspection,
initial color selection is not perfect.
It happens often that some colors are very similar and I have to
change some of them in order to distinguish them better
The very first colors may be chosen to be visually quite different
from each other.
Regards,
Gabriele Monfardini
