[Qgis-developer] USING qgis in c++ QT application on Windows
mina imene_yamina at yahoo.fr
Wed Sep 26 00:42:46 PDT 2012
hi,
I use QGIS in C++ QT Application with VC complier,
I had a lot of difficulties to make QGIS work on Windows .
The only solution I've found is to run QGIS  is to use compiled VC
librairies found in OSGeo4W.
But this solution causes me two problems:
1)There are plenty Qdebug message. it slowed enormously application and
sometimes makes bugs.
2)I have two windows where I should display the map. when I execute multiple
times, the card explodes outside the View where it should appear.
Can  anyone help me.
I do not know if this is the right place to post this message. but I do not
know where I could find a solution.
thank you in advance for your help
Imane
View this message in context: http://osgeo-org.1560.n6.nabble.com/USING-qgis-in-c-QT-application-on-Windows-tp5004513.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
