[Qgis-developer] QGIS globe and mapserver export plugin
Giuseppe Sucameli brush.tyler at gmail.com
Thu Apr 11 07:03:05 PDT 2013
Hi Hugo,
On Thu, Apr 11, 2013 at 2:42 PM, Hugo Mercier <hugo.mercier at oslandia.com>wrote:
> Le 02/04/2013 12:04, Giuseppe Sucameli a écrit :
> RT Mapserver Exporter plugin uses SLD as intermediary format for styles,
> > but it needs mapscript v6.2 which is not available on OSGeo4W yet.
> Just to let you know we have been working on a fork of this plugin
> during a sprint with Thomas Bonfort (from the MapServer project) to
> replace the use of SLD for conversion by direct calls to the mapscript API.
wow, I didn't notice you've forked it on GH and working on that!
BTW, I see there's another fork [1] as well as some issues was fixed by
both
you and "geonux" (e.g. using the epsg vs proj string).
What do you think about a brainstorming (even by email...) on how to
improve
it avoiding waste of time due effort on the same fixes?
I really like your work as in this moment MapServer has a weak SLD1.1
support,
BTW I hope you understand I've chosen SLD because this format is (or at
least
should become) the standard for style interchange, so unbound to different
API
implementations.
Best regards.
[1] https://github.com/faunalia/rt_mapserver_exporter/network
> The code can be found here :
> https://github.com/Oslandia/rt_mapserver_exporter/tree/nosld
> ... as well as a TODO list :
> https://github.com/Oslandia/rt_mapserver_exporter/wiki/Todo
> We mainly focused on the new symbology and most of the features are
> covered. There are still features that would be very hard to translate
> into mapserver terms.
> Let us know if you find this useful.
> Hugo Mercier
> Oslandia
> Qgis-developer mailing list
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130411/9b7acb33/attachment-0001.html>
