[Qgis-developer] symbology-ng-style.db and symbology-ng-style.xml
Borys Jurgiel
lists at borysjurgiel.pl
Sat Apr 13 02:05:36 PDT 2013
Dnia sobota, 13 kwietnia 2013 o 10:14:33 aruntheguy at gmail.com napisał(a):
> Kindly post if you need more clarification.
Thanks! Yes, it's exactly what I thought.
I understand the xml file in the source code should stay, because it's more
convenient to edit it and recreate the db with the script than to modify the
xml inside db cells. Last days I've made some fixes and updates to the symbols
this way.
