[Qgis-developer] wrong transformation of project on qgis 1.9.0
Andrea Peri aperi2007 at gmail.com
Tue Apr 16 14:41:37 PDT 2013
I have a 1.8.0 qgis project and try to open with the new qgis-dev version
of qgis.
To see how much compatible it will be with the next released version of
qgis.
Unfortunately I see it is pretty drammatically unusable.
Infact In the "old" project I have many projects where often the layers are
rendered with a "unique value" style of old symbology.
The reason to have used the unique value rendering is that it allow the
usage of the empty value as a conditional "all the other values".
And this is a "must" in the rendering in our usages.
But when I tryed to load this project with the new qgis dev I see that it
change from the "unique value" to the "categorized" style.
What a wrong choice !
Infact it don't allow the use of empty as "all the other" but use the empty
as only "empty" value :)
So I see all our objects simply disappeared from our project.
I guess when import from 1.8.0
qgis should use the unique value for the old unique value style.
And I guess this is a really blocking issue because
actually the qgis is "heavily" changing the qgis 1.8.0 project.
Regards,
Andrea.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130416/70f06d99/attachment.html>
