[Qgis-developer] PROBLEM SOLVED - QGIS Misses GetCapabilites Version - RE: Adding The Selection of Image Type To WMS Setup?
Bruce, Bob (CON) Bob.Bruce at gov.mb.ca
Wed Apr 17 15:17:42 PDT 2013
Jürgen,
	Thanks, that's great.
I upgraded my QGIS and I was able to connect to the WMS and see the image types without adding the &version=1.3.0 string and I did see the JPEG/PNG selection. When I selected that type and drew the whole area I did not get an image that had transparency so the underlying image was now showing where blank areas appeared. When I select JPEG/PNG is QGIS selecting an image format specified by image/x-jpegorpng or is it specified by something else? I am wondering if I should be looking to the server for the problem or looking to QGIS.
Thanks,
	Bob
-----Original Message-----
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: April-17-13 4:12 PM
To: 'qgis-developer at lists.osgeo.org'
Subject: Re: [Qgis-developer] PROBLEM SOLVED - QGIS Misses GetCapabilites Version - RE: Adding The Selection of Image Type To WMS Setup?
Hi Bruce,
On Wed, 17. Apr 2013 at 15:45:04 -0500, Bruce, Bob (CON) wrote:
> So I have two questions:
> 1) will QGIS soon accommodate a OGC GetCapabilites format version 1.3.2 document?
> 2) will it be possible to have the image type of jpegorpng allowed to be used?
Since sunday it does - see 6604d2f8146
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
