[Qgis-developer] Does Sextante Field Calculator support all functions of attribute table field calc?
Anita Graser
anitagraser at gmx.at
Thu Apr 18 10:15:24 PDT 2013
On Thu, Apr 18, 2013 at 9:21 AM, Alexander Bruy <alexander.bruy at gmail.com>wrote:
> BTW, there is also Advanced Field Calculator that should allow
> calculate area and perform much more complex calculations
Could you show me how?
value = $area / "area"
causes
File
"C:\OSGeo4W\apps\qgis-dev\python\plugins\sextante\core\GeoAlgorithm.py",
line 147, in execute
self.processAlgorithm(progress)
File
"C:\OSGeo4W\apps\qgis-dev\python\plugins\sextante\algs\FieldPyculator.py",
line 125, in processAlgorithm
unicode(sys.exc_info()[0].__name__), unicode(sys.exc_info()[1]))
TypeError: __init__() takes exactly 2 arguments (4 given)
Thanks!
Anita
> On Wed, 17 Apr 2013 22:42:05 +0200
> "Anita Graser" <anitagraser at gmx.at> wrote:
> > Hi,
> > I have a polygon layer with an "area" field and want to calculate $area /
> > "area". This works well in attribute table field calculator.
> > If I try to use Sextante Field Calculator, the resulting field contains
> > only NULL values. Is this supposed to work? Is this a bug you can
> confirm?
> > Best wishes,
> > Anita
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130418/4de0df9e/attachment.html>
