[Qgis-developer] Atlas and overview issues?
Andreas Neumann a.neumann at carto.net
Mon Apr 22 23:36:54 PDT 2013
 Hi Paolo,
 I would say 1) and 3) are just missing features. The client that paid
 for the overview map feature did not request what you want. They just
 had the overview map at full extent (that is what maybe 90% of users are
 doing) and did not want to zoom in and auto-center. 2) may be a bug.
 Could you open a bug request?
 regarding 3) will only work for polygon features - but Atlas also works
 with lines or points. So it needs special casing for polygons. A missing
 feature that you can ask Oslandia to implement. You will have to specify
 if you want this feature on the main map or the overview map or both.
 Andreas
 On Tue, 23 Apr 2013 08:09:13 +0200, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> I have tested in depth the Atlas and overview functions, and come out
> with a few issues:
> * an overview map is not autocentered, so if it does not cover the
> whole area, the
> overview does not appear on most prints: a known limitation, or am I
> missing an option?
> * feature filtering does not appear to be working with $rownum:
> again, a known
> limitation, or am I missing an option?
> * it would be good (and used in other software) to put a transparency
> outside the
> selected feature for each map: I remember this has been discussed on
> the ML, but I do
> not know what is the fate of this functions: is there and I did not
> find it, or is it
> something that has still to be developed? Any roadmap for this?
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlF2JYgACgkQ/NedwLUzIr7ywQCfTHiwl1dgGp2k8J1IdpILnWV8
> XC0AnjlToogmgJ2zURSFsDcgY6CQbO3R
> =cqvh
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
