[Qgis-developer] disjoint checking in geometry addPart
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Apr 23 01:11:00 PDT 2013
I am wondering if this is correct to check if polygons are disjoint when
trying to add a new part to a multipolygon.
https://github.com/qgis/Quantum-GIS/blob/master/src/core/qgsgeometry.cpp#L3009
Indeed if you try add a new part having a segment in common with an
existing part it won't be ok.
Also, while trying to slit parts, I cannot use addPart method as it is,
because the parts are not disjoint.
What do you think?
Should we rather use GEOSOverlaps ?
Thanks a lot
Denis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130423/32021cfe/attachment.html>
