[Qgis-developer] qgis-webclient - weblinks from features and base layers
Otto Dassau
dassau at gbd-consult.de
Tue Apr 23 23:54:44 PDT 2013
Hi Bernhard,
now <a class="popupLink" href="http://www.qgis.org">QGIS Homepage</a> also
works.
Thanks a lot
Otto
Am Tue, 23 Apr 2013 15:56:41 +0200
schrieb Otto Dassau <dassau at gbd-consult.de>:
> Hi Bernhard,
> thanks a lot for this, I will test it, once it is approved.
> Regards
> Otto
> Am Tue, 23 Apr 2013 15:50:45 +0200
> schrieb Bernhard Ströbl <bernhard.stroebl at jena.de>:
> > Otto,
> > I made a pull request fixing this issue. If a url is detected
> > (http://something) in an attribute it is checked whether there is an
> > opening "<a" - tag and only if this is false the tag is automagically
> > created. So if you store a complete html-formatted link in your
> > attribute it should be displayed as stored.
> > Bernhard
> > Am 23.04.2013 14:34, schrieb Otto Dassau:
> > > Hi Bernhard,
> > > yes, that doesn't work properly.
> > > ends up in a string ("QGIS Homepage' target="_blank">QGIS Homepage),
> > > where the second link (QGIS Homepage) works and the first one is wrong.
> > > So that doesn't work well.
> > > But<a href=http://www.qgis.org>QGIS Homepage</a> is fine.
> > > Regards
> > > Otto
> > > Am Tue, 23 Apr 2013 13:37:00 +0200
> > > schrieb Bernhard Ströbl<bernhard.stroebl at jena.de>:
> > >> Hi Otto,
> > >> you are right. This won't work. The automatic url detection is for
> > >> simpler cases where users store a pure url in a field. This url is
> > >> detected and displayed as a link without any html writing necessary.
> > >> So if you want to individually format a complete link with html tags
> > >> you may do it as you showed. If you do
> > >> <a class="popupLink" .... the link gets styled as defined in
> > >> popup.css. I cannot test currently but I think that you might get
> > >> another<a> tag around your link. Is that true?
> > >> Bernhard
> > >> Am 23.04.2013 12:47, schrieb Otto Dassau:
> > >>> Hi Bernhard,
> > >>> thanks for the hint, but how would that work in pratice, if I don't
> > >>> want to show the complete link but a description?
> > >>> At the moment to display "QGIS Homepage" I use:
> > >>> Regards
> > >>> Otto
> > >>> Am Tue, 23 Apr 2013 12:26:27 +0200
> > >>>> Hi Otto,
> > >>>> actually this works but is a bit outdated. If you are using the
> > >>>> latest webclient with the popups you should be able to simply store
> > >>>> an URL in a field and qwc automgically detects it and forms
> > >>>> the<a>-tag around it so it becomes a clickable link.
> > >>>> Bernhard
> > >>>> Am 23.04.2013 09:43, schrieb lami at gis3w.it:
> > >>>>> Hi Otto
> > >>>>> you can see the replay of Bernard Stroebl about this:
> > >>>>> http://lists.osgeo.org/pipermail/qgis-user/2012-October/019798.html
> > >>>>> Regards
> > >>>>> Leonardo
> > >>>>> On Tue, 23 Apr 2013 09:25:23 +0200, Otto
> > >>>>> Dassau<dassau at gbd-consult.de> wrote:
> > >>>>>> Hi,
> > >>>>>> is it possible to have clickable web links from features in the
> > >>>>>> qgis webclient? And if yes, would I need qgis master to use it?
> > >>>>>> And another question. I saw that e.g. qgiscloud allows to choose
> > >>>>>> base layers
> > >>>>>> from google, bing, ... with qgis webclient. This does not seem to
> > >>>>>> be
> > >>>>> part
> > >>>>>> of the "official" repository in github - right? Is it planned to
> > >>>>> integrate
> > >>>>>> this functionality or is somebody already working on it?
> > >>>>>> I found several mailings but not really a solution or clear hint.
> > >>>>>> Regards
> > >>>>>> Otto
> Qgis-developer mailing list
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support and analysis
Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
Community Advisor - QGIS Project Steering Committee
