[Qgis-developer] qgis-webclient - weblinks from features and base layers
Otto Dassau dassau at gbd-consult.de
Tue Apr 23 06:56:41 PDT 2013
Hi Bernhard,
thanks a lot for this, I will test it, once it is approved.
Regards
Otto
Am Tue, 23 Apr 2013 15:50:45 +0200
schrieb Bernhard Ströbl <bernhard.stroebl at jena.de>:
> Otto,
> I made a pull request fixing this issue. If a url is detected
> (http://something) in an attribute it is checked whether there is an
> opening "<a" - tag and only if this is false the tag is automagically
> created. So if you store a complete html-formatted link in your
> attribute it should be displayed as stored.
> Bernhard
> Am 23.04.2013 14:34, schrieb Otto Dassau:
> > Hi Bernhard,
> > yes, that doesn't work properly.
> > <a class="popupLink" href="http://www.qgis.org">QGIS Homepage</a>
> > ends up in a string ("QGIS Homepage' target="_blank">QGIS Homepage),
> > where the second link (QGIS Homepage) works and the first one is wrong.
> > So that doesn't work well.
> > But<a href=http://www.qgis.org>QGIS Homepage</a>  is fine.
> > Regards
> > Otto
> > Am Tue, 23 Apr 2013 13:37:00 +0200
> > schrieb Bernhard Ströbl<bernhard.stroebl at jena.de>:
> >> Hi Otto,
> >> you are right. This won't work. The automatic url detection is for
> >> simpler cases where users store a pure url in a field. This url is
> >> detected and displayed as a link without any html writing necessary.
> >> So if you want to individually format a complete link with html tags you
> >> may do it as you showed. If you do
> >> <a class="popupLink" .... the link gets styled as defined in popup.css.
> >> I cannot test currently but I think that you might get another<a>  tag
> >> around your link. Is that true?
> >> Bernhard
> >> Am 23.04.2013 12:47, schrieb Otto Dassau:
> >>> Hi Bernhard,
> >>> thanks for the hint, but how would that work in pratice, if I don't
> >>> want to show the complete link but a description?
> >>> At the moment to display "QGIS Homepage" I use:
> >>> Regards
> >>> Otto
> >>> Am Tue, 23 Apr 2013 12:26:27 +0200
> >>>> Hi Otto,
> >>>> actually this works but is a bit outdated. If you are using the latest
> >>>> webclient with the popups you should be able to simply store an URL
> >>>> in a field and qwc automgically detects it and forms the<a>-tag
> >>>> around it so it becomes a clickable link.
> >>>> Bernhard
> >>>> Am 23.04.2013 09:43, schrieb lami at gis3w.it:
> >>>>> Hi Otto
> >>>>> you can see the replay of Bernard Stroebl about this:
> >>>>> http://lists.osgeo.org/pipermail/qgis-user/2012-October/019798.html
> >>>>> Regards
> >>>>> Leonardo
> >>>>> On Tue, 23 Apr 2013 09:25:23 +0200, Otto
> >>>>> Dassau<dassau at gbd-consult.de> wrote:
> >>>>>> Hi,
> >>>>>> is it possible to have clickable web links from features in the qgis
> >>>>>> webclient? And if yes, would I need qgis master to use it?
> >>>>>> And another question. I saw that e.g. qgiscloud allows to choose
> >>>>>> base layers
> >>>>>> from google, bing, ... with qgis webclient. This does not seem to be
> >>>>> part
> >>>>>> of the "official" repository in github - right? Is it planned to
> >>>>> integrate
> >>>>>> this functionality or is somebody already working on it?
> >>>>>> I found several mailings but not really a solution or clear hint.
> >>>>>> Regards
> >>>>>> Otto
