[Qgis-developer] qgis-webclient - weblinks from features and base layers
Otto Dassau dassau at gbd-consult.de
Tue Apr 23 03:47:29 PDT 2013
Hi Bernhard,
thanks for the hint, but how would that work in pratice, if I don't want to
show the complete link but a description?
At the moment to display "QGIS Homepage" I use:
<a href=http://www.qgis.org>QGIS Homepage</a>
Regards
Otto
Am Tue, 23 Apr 2013 12:26:27 +0200
schrieb Bernhard Ströbl <bernhard.stroebl at jena.de>:
> Hi Otto,
> actually this works but is a bit outdated. If you are using the latest
> webclient with the popups you should be able to simply store an URL in a
> field and qwc automgically detects it and forms the <a>-tag around it so
> it becomes a clickable link.
> Bernhard
> Am 23.04.2013 09:43, schrieb lami at gis3w.it:
> > Hi Otto
> > you can see the replay of Bernard Stroebl about this:
> > http://lists.osgeo.org/pipermail/qgis-user/2012-October/019798.html
> > Regards
> > Leonardo
> > On Tue, 23 Apr 2013 09:25:23 +0200, Otto Dassau<dassau at gbd-consult.de>
> > wrote:
> >> Hi,
> >> is it possible to have clickable web links from features in the qgis
> >> webclient? And if yes, would I need qgis master to use it?
> >> And another question. I saw that e.g. qgiscloud allows to choose base
> >> layers
> >> from google, bing, ... with qgis webclient. This does not seem to be
> > part
> >> of the "official" repository in github - right? Is it planned to
> > integrate
> >> this functionality or is somebody already working on it?
> >> I found several mailings but not really a solution or clear hint.
> >> Regards
> >> Otto
