[Qgis-developer] qgis-webclient - weblinks from features and base layers
Bernhard Ströbl bernhard.stroebl at jena.de
Tue Apr 23 04:37:00 PDT 2013
Hi Otto,
you are right. This won't work. The automatic url detection is for
simpler cases where users store a pure url in a field. This url is
detected and displayed as a link without any html writing necessary.
So if you want to individually format a complete link with html tags you
may do it as you showed. If you do
<a class="popupLink" .... the link gets styled as defined in popup.css.
I cannot test currently but I think that you might get another <a> tag
around your link. Is that true?
Bernhard
Am 23.04.2013 12:47, schrieb Otto Dassau:
> Hi Bernhard,
> thanks for the hint, but how would that work in pratice, if I don't want to
> show the complete link but a description?
> At the moment to display "QGIS Homepage" I use:
> <a href=http://www.qgis.org>QGIS Homepage</a>
> Regards
> Otto
> Am Tue, 23 Apr 2013 12:26:27 +0200
> schrieb Bernhard Ströbl<bernhard.stroebl at jena.de>:
>> Hi Otto,
>> actually this works but is a bit outdated. If you are using the latest
>> webclient with the popups you should be able to simply store an URL in a
>> field and qwc automgically detects it and forms the<a>-tag around it so
>> it becomes a clickable link.
>> Bernhard
>> Am 23.04.2013 09:43, schrieb lami at gis3w.it:
>>> Hi Otto
>>> you can see the replay of Bernard Stroebl about this:
>>> http://lists.osgeo.org/pipermail/qgis-user/2012-October/019798.html
>>> Regards
>>> Leonardo
>>> On Tue, 23 Apr 2013 09:25:23 +0200, Otto Dassau<dassau at gbd-consult.de>
>>> wrote:
>>>> Hi,
>>>> is it possible to have clickable web links from features in the qgis
>>>> webclient? And if yes, would I need qgis master to use it?
>>>> And another question. I saw that e.g. qgiscloud allows to choose base
>>>> layers
>>>> from google, bing, ... with qgis webclient. This does not seem to be
>>> part
>>>> of the "official" repository in github - right? Is it planned to
>>> integrate
>>>> this functionality or is somebody already working on it?
>>>> I found several mailings but not really a solution or clear hint.
>>>> Regards
>>>> Otto
> __________ Information from ESET Mail Security, version of virus signature database 8256 (20130423) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
http://www.eset.com
