[Qgis-developer] QGIS 2.0 and PyQT v2 update
Denis Rouzaud
denis.rouzaud at gmail.com
Fri Apr 26 00:24:48 PDT 2013
On 04/25/2013 10:26 PM, Andreas Neumann wrote:
> Hi,
> It has been discussed that PyQT should be updated to v2 befor the QGIS
> 2.0 release. Is this still a feasible goal?
> I think it would be good to also update it before 2.0. With the new
> Vector API most plugin developers need to rework their plugins anyway.
> It would be good to also do the PyQT v2 update now.
+1
would be better to update the plugin at once!
> It would be bad if would release QGIS 2.0 without the PyQT v2 update and
> then shortly after we would break all plugins again, because of the PyQT
> v2 update.
> Is Martin the one who would work on this - or can/will others work on
> this as well? Martin - will you have time?
> Thanks,
> Andreas
> Qgis-developer mailing list
