[Qgis-developer] QGIS 2.0 and PyQT v2 update
Victor Olaya
volayaf at gmail.com
Fri Apr 26 00:27:24 PDT 2013
+1
I already discussed this with Andreas, and I agree 100%. If it is
feasible to do it before 2.0, it will be much better for all plugin
developers.
2013/4/26 Denis Rouzaud <denis.rouzaud at gmail.com>:
> Hi,
> On 04/25/2013 10:26 PM, Andreas Neumann wrote:
>> Hi,
>> It has been discussed that PyQT should be updated to v2 befor the QGIS
>> 2.0 release. Is this still a feasible goal?
>> I think it would be good to also update it before 2.0. With the new
>> Vector API most plugin developers need to rework their plugins anyway.
>> It would be good to also do the PyQT v2 update now.
> +1
> would be better to update the plugin at once!
>> It would be bad if would release QGIS 2.0 without the PyQT v2 update and
>> then shortly after we would break all plugins again, because of the PyQT
>> v2 update.
>> Is Martin the one who would work on this - or can/will others work on
>> this as well? Martin - will you have time?
>> Thanks,
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
