[Qgis-developer] Is Print Composer Atlas broken?
Anita Graser
anitagraser at gmx.at
Mon Apr 29 10:26:53 PDT 2013
Am 29.04.2013, 10:09 Uhr, schrieb Hugo Mercier <hugo.mercier at oslandia.com>:
> Le 28/04/2013 16:52, Anita Graser a écrit :
>> Hi,
>> I just wanted to test Atlas using lakes.shp from our sample data. The
>> resulting PDF has 15 pages but every page displays the same lake. Can
>> you confirm?
> Hi Anita,
> Tested here on a fresh git pull of the master branch (1959182), it works
> well with lakes.shp.
> Can you share your project file ?
Thanks Hugo,
When I create an empty project and test it, it works ...
I'll try to track the problem down and share a project file that doesn't
work. Unfortunately the current one is a bit messy :)
Best wishes,
Anita
