[Qgis-developer] The new installer
Denis Rouzaud denis.rouzaud at gmail.com
Mon Apr 29 22:54:31 PDT 2013
Well, I like the idea of having everything grouped.
For example in pyCharm everything is in one dialog: application and
project settings. And you can search for anything in a search bar.
If the left panels can be nested (as suggested previously), I would even
consider integrating the project settings in the main settings.
I would leave them directly accessible from menus of course, but just as
shortcuts leading to the main dialog but with the right panel open.
You then would have everything accessible at one place.
On 04/30/2013 07:46 AM, Nathan Woodrow wrote:
> On Tue, Apr 30, 2013 at 3:19 PM, Denis Rouzaud
> <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> wrote:
>     Do you think it could be interesting to integrate this also in the
>     settings dialog? If the left panel can be integrated as a tree
>     widget item in the panel of the settings dialog (as I just
>     proposed for the labelling).
> Not sure I follow that.  Why would you want plugins in the settings
> dialog?
> - Nathan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130430/75e77ad3/attachment.html>
