[Qgis-developer] The new installer
Nathan Woodrow madmanwoo at gmail.com
Mon Apr 29 22:59:45 PDT 2013
I don't mind the idea but I'm not for plugins living in the settings
dialog.  Plugins are not settings they are their own standalone thing.
Having some kind of settingsWidget() method exposed on each plugin that so
that we can add plugin settings in the settings dialog is not a bad idea,
but I think the installer and manager should live outside of the settings
dialog.
- Nathan
On Tue, Apr 30, 2013 at 3:54 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
>  Well, I like the idea of having everything grouped.
> For example in pyCharm everything is in one dialog: application and
> project settings. And you can search for anything in a search bar.
> If the left panels can be nested (as suggested previously), I would even
> consider integrating the project settings in the main settings.
> I would leave them directly accessible from menus of course, but just as
> shortcuts leading to the main dialog but with the right panel open.
> You then would have everything accessible at one place.
> On 04/30/2013 07:46 AM, Nathan Woodrow wrote:
> On Tue, Apr 30, 2013 at 3:19 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
>> Do you think it could be interesting to integrate this also in the
>> settings dialog? If the left panel can be integrated as a tree widget item
>> in the panel of the settings dialog (as I just proposed for the labelling).
> Not sure I follow that.  Why would you want plugins in the settings
> dialog?
>  - Nathan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130430/c0fb9f23/attachment.html>
