[Qgis-developer] The new installer
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Apr 29 23:06:01 PDT 2013
On 04/30/2013 07:59 AM, Nathan Woodrow wrote:
> I don't mind the idea but I'm not for plugins living in the settings
> dialog. Plugins are not settings they are their own standalone thing.
I understand. My point of view is that everything can be thought as a
setting, and some softs are doing this and I like it. But it's no big deal.
> Having some kind of settingsWidget() method exposed on each plugin
> that so that we can add plugin settings in the settings dialog is not
> a bad idea, but I think the installer and manager should live outside
> of the settings dialog.
That's a great idea. But it would be confusing as settings can be
application or project related. Unless you put everything in a dialog
setting ;) Joke apart, it's a great idea.
> - Nathan
> On Tue, Apr 30, 2013 at 3:54 PM, Denis Rouzaud
> <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> wrote:
> Well, I like the idea of having everything grouped.
> For example in pyCharm everything is in one dialog: application
> and project settings. And you can search for anything in a search bar.
> If the left panels can be nested (as suggested previously), I
> would even consider integrating the project settings in the main
> settings.
> I would leave them directly accessible from menus of course, but
> just as shortcuts leading to the main dialog but with the right
> panel open.
> You then would have everything accessible at one place.
> On 04/30/2013 07:46 AM, Nathan Woodrow wrote:
>> On Tue, Apr 30, 2013 at 3:19 PM, Denis Rouzaud
>> Do you think it could be interesting to integrate this also
>> in the settings dialog? If the left panel can be integrated
>> as a tree widget item in the panel of the settings dialog (as
>> I just proposed for the labelling).
>> Not sure I follow that. Why would you want plugins in the
>> settings dialog?
>> - Nathan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130430/c0741e06/attachment.html>
