[Qgis-developer] The new installer
Etienne Tourigny etourigny.dev at gmail.com
Tue Apr 30 07:21:17 PDT 2013
On Tue, Apr 30, 2013 at 2:59 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> I don't mind the idea but I'm not for plugins living in the settings
> dialog.  Plugins are not settings they are their own standalone thing.
+1
> Having some kind of settingsWidget() method exposed on each plugin that so
> that we can add plugin settings in the settings dialog is not a bad idea,
> but I think the installer and manager should live outside of the settings
> dialog.
+1
> - Nathan
> On Tue, Apr 30, 2013 at 3:54 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
>>  Well, I like the idea of having everything grouped.
>> For example in pyCharm everything is in one dialog: application and
>> project settings. And you can search for anything in a search bar.
>> If the left panels can be nested (as suggested previously), I would even
>> consider integrating the project settings in the main settings.
>> I would leave them directly accessible from menus of course, but just as
>> shortcuts leading to the main dialog but with the right panel open.
>> You then would have everything accessible at one place.
>> On 04/30/2013 07:46 AM, Nathan Woodrow wrote:
>> On Tue, Apr 30, 2013 at 3:19 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
>>> Do you think it could be interesting to integrate this also in the
>>> settings dialog? If the left panel can be integrated as a tree widget item
>>> in the panel of the settings dialog (as I just proposed for the labelling).
>> Not sure I follow that.  Why would you want plugins in the settings
>> dialog?
>>  - Nathan
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130430/9932cb11/attachment.html>
