[Qgis-developer] QgsDataProvider and supportsSubsetString
Nathan Woodrow
madmanwoo at gmail.com
Mon Apr 29 23:55:56 PDT 2013
Chris,
Also not there is previsions to add this kind of thing to QgsFeatureRequest
http://www.qgis.org/api/qgsfeaturerequest_8h_source.html
- Nathan
On Tue, Apr 30, 2013 at 4:33 PM, Chris Crook <ccrook at linz.govt.nz> wrote:
> Hi All
> As we are looking at API tidy ups (I understand), would there be any
> support for providing a bit more granularity in supportsSubsetString. At
> the moment this is a simple boolean, and the GUI offers a SQL based subset
> string builder.
> However not all providers naturally use SQL based strings. I'm interested
> in adding subset capability to the delimited text provider, whichi I've
> done using QgsExpression as the basis for subsets. This works very well
> except that the GUI isn't an expression builder. I think there may be
> similar issues with the WFS provider.
> What I am proposing is something more like an enum
> QgsDataProvider::SubsetStringType, which could then be interrogated by the
> properties dialog to select the appropriate query builder dialog.
> Logically this would supplant the supportsSubsetString boolean which could
> be deprecated, replaced with
> virtual QgsDataProvider::SubsetStringType
> QgsDataProvider::subsetStringType(){ return NoSubsetString; }
> Other types could be SqlSubsetString, ExpressionSubsetString, ...?
> Thoughts anyone?
> Thanks
> Chris
> This message contains information, which is confidential and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130430/88575c64/attachment-0001.html>
