[Qgis-developer] Renaming SEXTANTE
Alex Mandel
tech_dev at wildintellect.com
Sun Aug 11 15:14:41 PDT 2013
So is the proposal to change Analysis to Processing?
I don't think there's a reason to remove the SEXTANTE branding as
SEXTANTE does exist outside a QGIS context, ftools is another story
since that only exists in QGIS. I'm split on GDAL Tools, since it is
good to make sure users know what underlying tool is being used (ie in
the event they want to use the command line).
As for the Vector, Raster, etc menus... it's expected that over time
plugins will sort themselves into those menus in order to add
organization and make it more obvious what a tool does. It also makes
the generic plugins section smaller so that you don't have to wade
through 100 plugins to find the one you want.
The same applies for Analysis or Processing, I expect other analysis and
processing tools to exist that are not SEXTANTE but end up on the list,
in which case being able to tell it apart from what's there remains
important.
To me this is a UI question, not a core vs. non-core/c++ vs. python
question. ie: How do we organize and arrange menus to maximize discovery
of tools and ease workflow (fewer clicks or faster nav to the correct tool).
Analysis or Processing are both fine to me so +0 or maybe Advanced ....?
Thanks,
Alex
On 08/10/2013 10:53 PM, Saber Razmjooei wrote:
> +1 for changing name.
> I like GRASS menus, it has all the analytical modules under vector and
> raster menu. Can similar thing be done with SEXTANTE?
> Cheers
> Saber
> On 2013-08-10 12:23, Alexander Bruy wrote:
>> +1 from me to renaming.
>> Maybe we can use "Processing" or "GeoProcessing" as new name.
>> 2013/8/10 Nathan Woodrow <madmanwoo at gmail.com>:
>>> +1 from me too.
>>> Personally I find the core plugin concept unnecessary. If it's core it
>>> shouldn't be a plugin and should just be part of the main program.
>>> It can
>>> still be Python that is fine however users shouldn't have to turn
>>> them on
>>> and off they should just be there and be transparent.
>>> IMO we should aim to kill of all C++ core plugins in 2.1 and make
>>> them core
>>> features.Things like the geometry checking, spatial join, georeferencer
>>> should all be core features and have C++ and Python APIs that the
>>> user can
>>> use.
>>> - Nathan
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they are
> addressed. If you have received this email in error please notify the
> system manager. This message contains confidential information and is
> intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by e-mail if you have received this
> e-mail by mistake and delete this e-mail from your system. If you are
> not the intended recipient you are notified that disclosing, copying,
> distributing or taking any action in reliance on the contents of this
> information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to
> carry out such checks as you feel appropriate.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> Qgis-developer mailing list
