[Qgis-developer] Renaming SEXTANTE
Victor Olaya
volayaf at gmail.com
Sun Aug 11 15:36:52 PDT 2013
I wasn't very fond of this idea because or course I like the SEXTANTE
branding itself, but in terms of integration I now think it is better.
For a user that wants to do some analysis, keeping the SEXTANTE name
means that the user has to know that SEXTANTE is an analysis platform,
instead of just being able to look for analysis tools. The menu is
already called "analysis", so actually that's not going to be a big
problem, but then it doesn't make much sense to have named plugins,
specially if it's a core plugin.
I disagree in that it's a good thing to keep names in other plugins or
tools, such as GDAL tools. It looks like a good idea to most of us,
because we *know* what GDAL is. For those that don't (and could find
those tools very useful), "GDAL tools" means nothing. One of the main
goals of the SEXTANTE toolbox is to hide the origin of the algorithms
that are run. The user doesn't need to know if it's GRASS, or SAGA, or
OTB, or it is a native python algorihtm. Advanced users can use the
advanced mode, which shows that, but non-advanced ones (the vast
majority,,,) will find if much easier to just look for the algorithm
that they need.
Thanks a lot for your suggestions!
Cheers
VIctor
2013/8/12 Alex Mandel <tech_dev at wildintellect.com>:
> So is the proposal to change Analysis to Processing?
> I don't think there's a reason to remove the SEXTANTE branding as
> SEXTANTE does exist outside a QGIS context, ftools is another story
> since that only exists in QGIS. I'm split on GDAL Tools, since it is
> good to make sure users know what underlying tool is being used (ie in
> the event they want to use the command line).
> As for the Vector, Raster, etc menus... it's expected that over time
> plugins will sort themselves into those menus in order to add
> organization and make it more obvious what a tool does. It also makes
> the generic plugins section smaller so that you don't have to wade
> through 100 plugins to find the one you want.
> The same applies for Analysis or Processing, I expect other analysis and
> processing tools to exist that are not SEXTANTE but end up on the list,
> in which case being able to tell it apart from what's there remains
> important.
> To me this is a UI question, not a core vs. non-core/c++ vs. python
> question. ie: How do we organize and arrange menus to maximize discovery
> of tools and ease workflow (fewer clicks or faster nav to the correct tool).
> Analysis or Processing are both fine to me so +0 or maybe Advanced ....?
> Thanks,
> Alex
> On 08/10/2013 10:53 PM, Saber Razmjooei wrote:
>> +1 for changing name.
>> I like GRASS menus, it has all the analytical modules under vector and
>> raster menu. Can similar thing be done with SEXTANTE?
>> Cheers
>> Saber
>> On 2013-08-10 12:23, Alexander Bruy wrote:
>>> +1 from me to renaming.
>>> Maybe we can use "Processing" or "GeoProcessing" as new name.
>>> 2013/8/10 Nathan Woodrow <madmanwoo at gmail.com>:
>>>> +1 from me too.
>>>> Personally I find the core plugin concept unnecessary. If it's core it
>>>> shouldn't be a plugin and should just be part of the main program.
>>>> It can
>>>> still be Python that is fine however users shouldn't have to turn
>>>> them on
>>>> and off they should just be there and be transparent.
>>>> IMO we should aim to kill of all C++ core plugins in 2.1 and make
>>>> them core
>>>> features.Things like the geometry checking, spatial join, georeferencer
>>>> should all be core features and have C++ and Python APIs that the
>>>> user can
>>>> use.
>>>> - Nathan
>> This email and any files transmitted with it are confidential and
>> intended solely for the use of the individual or entity to whom they are
>> addressed. If you have received this email in error please notify the
>> system manager. This message contains confidential information and is
>> intended only for the individual named. If you are not the named
>> addressee you should not disseminate, distribute or copy this e-mail.
>> Please notify the sender immediately by e-mail if you have received this
>> e-mail by mistake and delete this e-mail from your system. If you are
>> not the intended recipient you are notified that disclosing, copying,
>> distributing or taking any action in reliance on the contents of this
>> information is strictly prohibited.
>> Whilst reasonable care has been taken to avoid virus transmission, no
>> responsibility for viruses is taken and it is your responsibility to
>> carry out such checks as you feel appropriate.
>> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
