[Qgis-developer] Digitizing behavior
Andreas Neumann
a.neumann at carto.net
Tue Aug 20 02:17:16 PDT 2013
I just tested with a new Shapefile - no difference before and after the
save.
It seems that the newest feature always gets row id 0 and the other
features get incremented - this is very odd and against every behavior
of other spreadsheets and databases.
But I am pretty sure that earlier versions did not show this behavior.
Andreas
On Tue, 20 Aug 2013 11:10:40 +0200, Denis Rouzaud wrote:
> not sure but to-be-commited features have negative IDs. It might be a
> reason they are rendered first.
> On 08/20/2013 11:07 AM, Andreas Neumann wrote:
>> Hi Salvatore,
>> I think you described it wrong: the former is on the top and not the
>> latter. If the latter were at the top it would be more logical and
>> like the other GIS.
>> I agree that the current QGIS behavior is strange and I wonder why
>> this happens. Aren't objects rendered by its order in a table unless
>> there are other rules?
>> Andreas
>> On Mon, 19 Aug 2013 23:48:16 +0200, Salvatore Larosa wrote:
>>> I'm noticing that while digitizing a new feature which overlaps
>>> another, the latter is at the top although I expect to see it at
>>> the
>>> bottom, so the new feature should overlap to the existent one.
>>> I was wondering if this was the correct behavior since other GIS
>>> software have a different behavior.
>>> Do you think we can change this for the upcoming 2.0?
>>> Best Regards
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
