[Qgis-developer] Digitizing behavior
Nathan Woodrow madmanwoo at gmail.com
Tue Aug 20 02:31:01 PDT 2013
Unless it's a regression or causes data corruption I'm not a fan of making
it as a blocker.
- Nathan
On Tue, Aug 20, 2013 at 7:20 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> I just tried to remove the layer, add it again. Then the behavior changes
> a bit. New features still appear at the bottom, but after a save they move
> back to the top.
> Definitely something is broken.
> Can you open a blocker, Salvatore?
> Thanks,
> Andreas
> On Tue, 20 Aug 2013 11:17:16 +0200, Andreas Neumann wrote:
>> I just tested with a new Shapefile - no difference before and after the
>> save.
>> It seems that the newest feature always gets row id 0 and the other
>> features get incremented - this is very odd and against every behavior
>> of other spreadsheets and databases.
>> But I am pretty sure that earlier versions did not show this behavior.
>> Andreas
>> On Tue, 20 Aug 2013 11:10:40 +0200, Denis Rouzaud wrote:
>>> not sure but to-be-commited features have negative IDs. It might be a
>>> reason they are rendered first.
>>> On 08/20/2013 11:07 AM, Andreas Neumann wrote:
>>>> Hi Salvatore,
>>>> I think you described it wrong: the former is on the top and not the
>>>> latter. If the latter were at the top it would be more logical and like the
>>>> other GIS.
>>>> I agree that the current QGIS behavior is strange and I wonder why this
>>>> happens. Aren't objects rendered by its order in a table unless there are
>>>> other rules?
>>>> Andreas
>>>> On Mon, 19 Aug 2013 23:48:16 +0200, Salvatore Larosa wrote:
>>>>> I'm noticing that while digitizing a new feature which overlaps
>>>>> another, the latter is at the top although I expect to see it at the
>>>>> bottom, so the new feature should overlap to the existent one.
>>>>> I was wondering if this was the correct behavior since other GIS
>>>>> software have a different behavior.
>>>>> Do you think we can change this for the upcoming 2.0?
>>>>> Best Regards
>>>> ______________________________**_________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130820/5e14b7bc/attachment.html>
