[Qgis-developer] Digitizing behavior
Jürgen E. Fischer
jef at norbit.de
Tue Aug 20 02:47:14 PDT 2013
Hi Salvatore,
On Mon, 19. Aug 2013 at 23:48:16 +0200, Salvatore Larosa wrote:
> I'm noticing that while digitizing a new feature which overlaps another,
> the latter is at the top although I expect to see it at the bottom, so the
> new feature should overlap to the existent one.
IMHO the render order should be considered arbitrary. The provider doesn't
return the features in a particular order later anyway.
Currently (w/o Matthias patch) while the layer is edited feature with changed
geometries are rendered first (ie. bottom), then added features and then
features from the provider (- those that are going to be deleted).
I don't think that this must be changed. If a layer can have overlapping
features, it probably should be configured to show them transparently already.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
committ(ed|ing) to QGIS IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
