[Qgis-developer] Digitizing behavior
Salvatore Larosa
lrssvtml at gmail.com
Tue Aug 20 03:14:59 PDT 2013
Hi Jürgen
2013/8/20 Jürgen E. <jef at norbit.de>
> Hi Salvatore,
> On Mon, 19. Aug 2013 at 23:48:16 +0200, Salvatore Larosa wrote:
> > I'm noticing that while digitizing a new feature which overlaps
> another,
> > the latter is at the top although I expect to see it at the bottom,
> so the
> > new feature should overlap to the existent one.
> IMHO the render order should be considered arbitrary. The provider doesn't
> return the features in a particular order later anyway.
> Currently (w/o Matthias patch) while the layer is edited feature with
> changed
> geometries are rendered first (ie. bottom), then added features and then
> features from the provider (- those that are going to be deleted).
> I don't think that this must be changed. If a layer can have overlapping
> features, it probably should be configured to show them transparently
> already.
Yes, you're right and this is a particular case and we can use transparency
if there are overlapping features,
mine was only a reflection on how other software behaved with such a
similar thing.
Nevertheless my vote is for apply Matthias's patch!
Thanks,
-SL
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> committ(ed|ing) to QGIS IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130820/a5385553/attachment.html>
