[Qgis-developer] Need help with Plugin button behavior connected to SIGNAL("selectionChanged()")
Nathan Woodrow
madmanwoo at gmail.com
Thu Aug 22 05:29:50 PDT 2013
This is not going to solve you problem yet but this is a quick refactor to
use the new style signal slot syntax:
def initGui(self):
# Create action that will start plugin configuration
self.action = QAction(
QIcon(":/plugins/splitmultipart/icon.svg"),
QCoreApplication.translate('Multipart split', u"Split Selected
Multipart features"), self.iface.mainWindow())
self.action.setEnabled(False)
# connect to signals for button behavior
self.action.triggered.connect(self.run)
self.iface.currentLayerChanged.connect(self.toggle)
# Add toolbar button and menu item
self.iface.advancedDigitizeToolBar().addAction(self.action)
self.iface.editMenu().addAction(self.action)
def toggle(self, layer):
mc = self.canvas
layer = mc.currentLayer()
# Decide whether the plugin button is enable or disable
if layer:
# set enable
if layer.isEditable():
layer.editingStopped.connect(self.toggle)
layer.editingStarted.disconnect(self.toggle)
layer.selectionChanged.connect(self.toggle)
self.iface.messageBar().pushMessage("Debug"," Connect
SIGNAL(selectionChanged()",0)
if layer.selectedFeatureCount() > 0:
self.action.setEnabled(True)
else:
# set disable
else:
layer.editingStarted.connect(self.toggle)
layer.editingStopped.disconnect(self.toggle)
layer.selectionChanged.disconnect(self.toggle)
self.iface.messageBar().pushMessage("Debug"," Disconnect
On Thu, Aug 22, 2013 at 10:11 PM, Alexandre Neto <senhor.neto at gmail.com>wrote:
> Hello all,
> I'm updating the Multipart split plugin<http://plugins.qgis.org/plugins/splitmultipart/> to
> make it work with the 2.0 API.
> Has I have successfully updated the plugin to make it work in 2.0, I would
> like to improve it's button behavior to work like the rest of the advanced
> editing toolbar. I am able to enable and disable it if the current layer is
> editable.
> Now I'm trying to get the same behavior if there are selected features. I
> have made it work, but QGIS starts to get really slow... I found out that's
> because lots of connections are being created to
> SIGNAL("selectionChanged()").
> Can someone please, point me in the right direction, or tell me where can
> I find some code example doing this?
> Thank you very much,
> Alexandre Neto
> Part of the code bellow:
> def initGui(self):
> QObject.connect(self.action, SIGNAL("triggered()"), self.run)
> QObject.connect(self.iface,
> SIGNAL("currentLayerChanged(QgsMapLayer*)"), self.toggle)
> #QObject.connect(self.iface, SIGNAL("selectionChanged(QgsMapLayer
> *)"), self.toggle)
> def toggle(self):
> mc = self.canvas
> if layer <> None:
> # set enable
> QObject.connect(layer,SIGNAL("editingStopped()"),self.toggle)
> QObject.connect(layer, SIGNAL("selectionChanged()"),
> self.toggle)
> QObject.disconnect(layer,SIGNAL("editingStarted()"),self.toggle)
> else:
> # set disable
> else:
> QObject.connect(layer,SIGNAL("editingStarted()"),self.toggle)
> QObject.disconnect(layer,SIGNAL("editingStopped()"),self.toggle)
> QObject.disconnect(layer, SIGNAL("selectionChanged()"),
> self.toggle)
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130822/64ae7c45/attachment.html>
