[Qgis-developer] Need help with Plugin button behavior connected to SIGNAL("selectionChanged()")
Alexandre Neto
senhor.neto at gmail.com
Thu Aug 22 08:29:26 PDT 2013
Hello Nathan,
After I resolved my problem with Denis suggestion I tried to apply your
refactor to use the new style. The code seems much simpler. But I got two
errors while running it (see code below).
If I add 'layer' as an argument for the toggle function, I get the
following error. It works without the change, can you please explain why
should layer be passed as an argument too?
An error has occured while executing Python code:
> TypeError: toggle() takes exactly 2 arguments (1 given)
> Python version:
> 2.7.4 (default, Apr 6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
> Traceback (most recent call last):
> File
> "C:\Users\alexandre.neto/.qgis2/python/plugins\splitmultipart\splitmultipart.py",
> line 84, in toggle
> layer.editingStopped.disconnect(self.toggle)
> TypeError: 'instancemethod' object is not connected
Also, trying to use,
instead of,
QObject.disconnect(layer,SIGNAL("editingStopped()"),self.toggle)
Gives me this other error:
> File
> line 83, in toggle
> Python version:
Thank you very much for your help,
Alexandre Neto
The new code would be:
def initGui(self):
> # Create action that will start plugin configuration
> self.action = QAction(
> QIcon(":/plugins/splitmultipart/icon.svg"),
> QCoreApplication.translate('Multipart split', u"Split Selected
> Multipart features"), self.iface.mainWindow())
> self.action.setEnabled(False)
> # connect to signals for button behavior
> self.action.triggered.connect(self.run)
> self.iface.currentLayerChanged.connect(self.toggle)
> self.canvas.selectionChanged.connect(self.toggle)
> # Add toolbar button and menu item
> self.iface.advancedDigitizeToolBar().addAction(self.action)
> self.iface.editMenu().addAction(self.action)
> def toggle(self):
> layer = self.canvas.currentLayer()
> # Decide whether the plugin button is enable or disable
> if layer:
> # set enable
> if layer.isEditable() and layer.selectedFeatureCount() > 0:
> self.action.setEnabled(True)
> layer.editingStopped.connect(self.toggle)
> layer.editingStarted.disconnect(self.toggle)
> # set disable
> else:
> layer.editingStarted.connect(self.toggle)
On Thu, Aug 22, 2013 at 1:29 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> This is not going to solve you problem yet but this is a quick refactor to
> use the new style signal slot syntax:
> def initGui(self):
> def toggle(self, layer):
> mc = self.canvas
> layer = mc.currentLayer()
> if layer:
> # set enable
> if layer.isEditable():
> layer.selectionChanged.connect(self.toggle)
> self.iface.messageBar().pushMessage("Debug"," Connect
> SIGNAL(selectionChanged()",0)
> if layer.selectedFeatureCount() > 0:
> else:
> # set disable
> else:
> layer.selectionChanged.disconnect(self.toggle)
> self.iface.messageBar().pushMessage("Debug"," Disconnect
> On Thu, Aug 22, 2013 at 10:11 PM, Alexandre Neto <senhor.neto at gmail.com>wrote:
>> Hello all,
>> I'm updating the Multipart split plugin<http://plugins.qgis.org/plugins/splitmultipart/> to
>> make it work with the 2.0 API.
>> Has I have successfully updated the plugin to make it work in 2.0, I
>> would like to improve it's button behavior to work like the rest of the
>> advanced editing toolbar. I am able to enable and disable it if the current
>> layer is editable.
>> Now I'm trying to get the same behavior if there are selected features. I
>> have made it work, but QGIS starts to get really slow... I found out that's
>> because lots of connections are being created to
>> SIGNAL("selectionChanged()").
>> Can someone please, point me in the right direction, or tell me where can
>> I find some code example doing this?
>> Thank you very much,
>> Alexandre Neto
>> Part of the code bellow:
>> def initGui(self):
>> Selected Multipart features"), self.iface.mainWindow())
>> QObject.connect(self.action, SIGNAL("triggered()"), self.run)
>> QObject.connect(self.iface,
>> SIGNAL("currentLayerChanged(QgsMapLayer*)"), self.toggle)
>> #QObject.connect(self.iface, SIGNAL("selectionChanged(QgsMapLayer
>> *)"), self.toggle)
>> def toggle(self):
>> mc = self.canvas
>> if layer <> None:
>> # set enable
>> QObject.connect(layer,SIGNAL("editingStopped()"),self.toggle)
>> QObject.connect(layer, SIGNAL("selectionChanged()"),
>> self.toggle)
>> QObject.disconnect(layer,SIGNAL("editingStarted()"),self.toggle)
>> else:
>> # set disable
>> else:
>> QObject.connect(layer,SIGNAL("editingStarted()"),self.toggle)
>> QObject.disconnect(layer, SIGNAL("selectionChanged()"),
>> self.toggle)
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130822/78194e18/attachment.html>
