[Qgis-developer] Saga and sextante on OSX
John C. Tull jctull at gmail.com
Tue Aug 27 12:47:57 PDT 2013
Hi everyone,
I'm running trunk on OS X 10.8 with qgis dependencies built from source (most using the homebrew package manager). I also have a functional saga_cmd binary that I can use in my terminal to produce valid outputs. Unfortunately, sextante complains when I try to run a function:
" Missing dependency.This algorithm cannot be run :-(
This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is not installed in your system, or it is not correctly configured to be used from QGIS"
This perplexes me. The appropriate path, "/usr/local/bin" shows in my qgis preferences. Sextante was also working at least several months ago in trunk. Can anyone provide any suggestions on what may be causing this to not work?
Thanks,
John
