[Qgis-developer] Saga and sextante on OSX
Salvatore Larosa
lrssvtml at gmail.com
Wed Aug 28 15:07:03 PDT 2013
Il giorno martedì 27 agosto 2013, John C. Tull ha scritto:
> Hi everyone,
> I'm running trunk on OS X 10.8 with qgis dependencies built from source
> (most using the homebrew package manager). I also have a functional
> saga_cmd binary that I can use in my terminal to produce valid outputs.
> Unfortunately, sextante complains when I try to run a function:
> " Missing dependency.This algorithm cannot be run :-(
> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA
> is not installed in your system, or it is not correctly configured to be
> used from QGIS"
if you are running with SAGA 2.0.8, there should be an option under
Processing-->Processing options in SAGA Provider ticks "Enable SAGA 2.0.8
compatibility". That should allow you to run SAGA algs.
Regards,
-SL
> This perplexes me. The appropriate path, "/usr/local/bin" shows in my qgis
> preferences. Sextante was also working at least several months ago in
> trunk. Can anyone provide any suggestions on what may be causing this to
> not work?
> Thanks,
> John
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130829/e1c61f09/attachment.html>
